Can someone tell me if my camera should auto connect with the iPhone when using geotagging or do I have to connect it every time the camera powers down?
Many thanks for replying, I actually contacted Sony's customer service and they said the same as you, I have to pair it every time. Hopefully the RX10 MKV will have a built in geotagging.
Kind regards
Hi there,
Let me look into this for you and I will update the thread when I have an answer.
Best wishes,
Sean
Hi Jpegman ,
Do you mean pairing the camera with the phone?
Cheers,
The_Black_Rose
Correct, I find I need to pair my IPhone and camera every time I switch on or the camera shuts down to save power, I was wondering if this was normal or was I doing something wrong.
Hi Jpegman,
I believe you'll need to pair them every time. Have you tried connecting them via the WiFi option?
Cheers,
The_Black_Rose
