Hi, I have recently installed PlayMemories home to my computer and uploaded pictures to it. When I view them through Calender, The pictures are showing up all over the place. I have some showing back as far as 1907 (before I was born) and others have gone into 2023. Is there a way of sorting this out
Hi @WarrantX1145,
PMH reads the time stamp of the files (part of the EXIF data) and uses that time stamp for the calendar view. If for whatever reason the time stamp contains wrong values like the year 1907 PMH cannot know the correct date. You'd need to alter those false dates manually, I'm afraid.
darkframe
Hey, you can edit it on the app itself https://www.sony.co.uk/electronics/support/e-mount-body-ilce-7-series/ilce-7m3/articles/00152041
Hi @HannahEd01,
I'm afraid that it won't be that easy because you cannot alter the date of a picture by means of the printing feature. So if in an image e.g. 01.12.1907 is stored in the EXIF data you'll only be able to tell PMH in which format you'd like the date to be printed but you cannot change it to e.g. 01.12.2007.
darkframe
