I have just downloaded the Imaging Edge Mobile app onto my new iPad to find that the RX10 is no longer supported for remote shooting like it was in the old play memories app. Any suggestions as I use to use remote shooting a lot
Hi there,
Hopefully a community member can help.
Best wishes,
M
Hi Apenny75,
I've just had a look into the supported functions for each camera. With Imaging edge mobile, it's still possible to control the camera using the smart phone: https://support.d-imaging.sony.co.jp/www/cscs/pmm/products.php?area=gb&lang=en&mnt=1
What happens when you try to use the function?
Cheers,
The_Black_Rose
