recently It pops up in the screen an extra focus frames which tilts all the time and does not have any function rather than to confuse me
I tried to erase it without succeed , is there anyone with a solution ?
Thank you in advance
I don’t know what you done. But if you are in panic mode, simply reset the camera to initial setup and go..
Take a note of your personalisations, and initialize https://helpguide.sony.net/ilc/2110/v1/en/contents/TP1000616558.html
The problem is fixed
Thank you !!!
