My old cybershot had the ability to force the flash to flash while taking a photo but the TX5 does not seem to have this functionality. It has either Auto-Flash or Off.
Any idea if this can be enabled?
Thanks
The specifications seem to imply that 'Flash On' is a menu option?
| AF Illuminator | YES |
| Flash Mode | Auto / Flash On / Slow Syncro / Flash Off |
| Distance limitations using Flash (m) | ISO Auto: Approx.0.08-Approx.2.9m(Approx.0.26'-Approx.9.51')(W) / Approx.0.5-Approx.2.4m(Approx.1.64'-Approx.7.87')(T), ISO3200: up to Approx.6.0m(Approx19.7)(W) / Approx.4.7m(Approx15.4')(T) |
| Pre-flash | YES |
| Red-eye Reduction | YES |
| Auto Daylight Synchronized Flash | YES |
However, these may not all be available in Intelligent Auto shooting mode. Are you using IA? Try Program Auto and see what options are offered.
| Pre-flash | YES |
Thank You that has sorted it, the answer seems so obvious now.
