I have recently bought a DSC-TX10 will my old memory stick pro duo work in it as when i load it in the camera does not reconise it! HELP:smileyconfused:
It should work for still images but you will need the Mark 2 PRO Duo for recording movies.
The following Memory Sticks are compatible: -
Memory Stick™ Duo. Memory Stick PRO Duo™(Mark2 only for movie). Memory Stick PRO Duo™ High Speed
In addition the following SD Cards are compatible: -
SD Memory Card(Class4 or Higher for movie), SDHC/SDXC Memory Card(Class4 or Higher for movie)
Thankyou:smileylaugh:
