I want to hook it up as a webcam but I am unsure how to proceed with this. I want to use it with OBS.
When I connect it with its multiport, my computer recognizes it as Mass USB Storage.
Yes you can use it as a webcam.
Information can be found here.
And of course here.
If you need further assistance, don't hesitate to ask.
Hi @Strampke,
are you sure?
The DSC-WX500 is not on the list of supported cameras as far as I can see.
- Nic
Have you gotten this working?
@KvInno if you have a WX500, it is not one of the Cameras compatible with the Imaging Edge Webcam...
