Lots of people are struggling with camera settings or just use auto mode.
Your camera hides a lot of options to enhance your pictures.
By default the Fn button hides a quick navi screen where you can set most settings in just a few clicks.
No menu searching, everything under your thumb.
In Auto mode the quick navi menu has fewer options, however there's help at hand by pushing the lower side of the control wheel.
Here you can adjust brightness, color, vividmes and special effects very easy.
