I have the following model. Sony Vaio SVF152A29M Laptop. I cannot find it in compatability lists to confirm if Windows 10 is yet compatible. The system I bought new onjy 30 months ago. Even my olf Toshiba has taken Windows 10 and it is 8 years old. Could you please inform me as the Vaio Information centre is very vague and the Laptop may have been superceeded. I bought my product in Germany but cannot ask a question on the German site as I registered in UK and it keep sending me here. Thanks.
Hi Fallyman,
this seems to be the chassis number of your PC - please check for a model code that starts with VPC...
Using this code you should be able to fnd the needed information on our support website.
Have a nice day
BTW: There's also an English community from Sony: community.sony.co.uk.
Hi Fallyman
for your Model will be prepared. If you want to Update than please create your Rescue Disks and after than Install the Update to Windows 10. Maybe it there are problems but in most cases all works without problems.
On this site you can Check if your Model compatible with Windows 10 or not.
https://www.sony.de/support/de/windows10#product-selector
Have a nice day
Burak
