I have an old Video 8 Handycam CCR-TR60E (26 years old) and wish to convert the tape to DVD. I have lost the user manual and cannot find the exact one on line, but can anyone tell me what the AV output is? SVideo etc? I can find a UM for a slightly different version but the output connectivity is different.
I am also looking for some guidance on the hardware/Software I need to facilitate using this camera with my Windows 10 OS via USB
Hi Dave,
If I remember correctly CCD-TR60 had video out only.
You should have two RCA connectors on the back: yellow > video and black > sound.
Basically you would need a video grabber for your computer to get the videos into your computer.
Hi Peter,
That's great. Thanks.
Do you have any recommendations for a screen grabber?
Regards
Dave
