hi folks, did this about 6 yrs ago so i know that it works but can't remember/get it going now
VCR into DCR-HC30 using the a/v slot then DV/firewire from (DCR-HC30) to PC (firewire slot)
win 7 on PC, it see's the fire wire card (and I can install a second firewire card ok) but nothing happens when i connect to the handycam
i've got windv software on pc but it can't see the handycam
think the software i used 6yrs ago was Sony Vegas or Pinnacle or Ulead stuff
I've set the AV-DV to OUT, but I sure when i did it 6 yrs ago I had to set something else in the Handycam menu (but I cant remember)
any help out there please
tried just the VCR to PC using easycap and the video is poor and jumpy,
Normally when using FireWire there is one device that needs to play and another that needs to record then Play one Rec the other.
Could it be that 6 years ago you first recorded in the camcorder and then transferred to the computer?
no, 6 yrs ago it was as I said, VCR to sony Handycam (DCR-HC30) then connected to PC
think i may have sorted it (hopefully)
tried the firewire port on pc (front) handycam not picked up, fitted a firewire card, card picked up but not the handycam, found a hidden firewire port on back of pc (well hidden if you are tii vain to get your eyes tested or wear glasses)
plugged handycam in back port, pc picked up handycam, but no video on screen, looks like i need a new scart connector (type you plug the audio/video jacks into) needs to be scart OUT not IN, or connectors for the jack plugs
hopefully photos show what i mean,
Hey rustyg, what are you aiming to do with this connection? Transferring stuff?
yes transfer old VHS tapes in a VCR though old sony handycam on to pc
managed to sort out the firewire conncetions now
but trouble is i have pinnacle studio as software and a 3hr vcr tape is about 40gb on the hard drive
did try virualdub & virturaldub 2 was only 5gbon hard drive but picture was awful
Hey there, the procedure I know uses Play Memories Home or Windows Live Photo Gallery: https://www.sony.co.uk/electronics/support/articles/00172974
