Hi could anyone help me, I am looking for a driver for a handycam DCR-PC101E for a mac computer?
thanks
Hi, welcome to the Sony Forums
The drivers for USB devices are built into the Mac OS, so you should be able to plug in and play, pretty much. Launch iMovie, click the small camera icon and the camera footage should appear as clips on iMovie's timeline.
If you have any problems I'm sure we'll be able to help.
Mick
Edit: if your Mac has a firewire port you'll get better transfer rates and more reliable conection using a 4pin to 6pin firewire cable like this http://www.abelcine.com/store/image.php?type=P&id=1000715 connected to the DV-out port on the camera.
Message was edited by: Mick2011
