where can I buy a USB cable to connect my old Sony DCR-HC22E handycam to my PC?
Hello Soozekyoo - Welcome to the Sony Forums
I had a quick look online and the best option seems to be eBay. Rather than direct you to a particular auction (as these can come and go) if you type 'DCR-HC22E Usb Cable' into the search box you will see various options starting at around £2.
Thanks,
Simon
Thanks,
Simon
