- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
HELP!! I bought a Bloggie in the US en-route back to UK on Sunday. Now I find the Bloggie software will not install on my Dell laptop running Vista Home Premium. Has anyone encountered a similar problem and is there an answer for it?
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I managed to fix this problem on my PC - if you are using Trusteer Rapport (anti-fraud software sent by HSBC of firstdirect) then remove it and the Bloggie software works fine after a reboot.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I'm having similar problems getting the Bloggie Touch software to run on my (UK) Windows 7 PC.
It loads, but won't start up. I can't find any references to this in the official support section but it seems to start up OK on an old laptop running XP.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi -- I'm working with a couple of people from Sony UK who have responded to my pleas on Twitter. Hopefully this will sort out my problem with Vista Home Premium. Sorry this doesn't help your problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi -- many thanks. This has worked. Very grateful. Thanks again!
