how can I unformat an DVD+RW formated accidentally on my handycam?
Hi sonyalexb, welcome to the Sony Forums
You might get some results using recovery software such as Badcopy although I haven't used it for years..
A professional data recovery firm will be expensive, but will give you the best possible chance of retrieving and must-have files.
Good luck
Mick
Good luck
Mick
You can unformat your hard drives or your flash drives, but not sure if there's any way to unformat or recover your files from your formatted DVD+RW.
Thanks, I'll try.
Alex
thanks
I used BadCopy Pro and succeeded to save to the hard disk all the lost videos!!
I even found a record 2 years ago !
Thanks again for your help, Mick2011.
I have used File Scavenger for years and think it works very very well, but I'm not sure if it will work on CDs or DVDs
thank you
I solved the problem with BadCopy Pro. It worked great
Worked great for me too
it is amazing, I recovered the lost movie that was important for me
