Hi DM2007 and welcome.
I presume you have a DCR-PC9E.
As you say, transfer by USB is not supported unless you are using Windows XP.
If your PC has a PC Card slot or an ExpressCard Slot, you can buy a card with firewire/iLink inputs and transfer the video digitally using something like the free Windows Movie Maker software..
If your PC has neither iLink or a Card slot, you cannot transfer digital video and will need to transfer using the AV Cable supplied with the camera (Jack plug to Yellow/Red/White phono plugs). You will need to buy a USB Video Capture Device and connect these Y/R/W plugs to the capture device. There are many such devices available from Amazon from £5 to £100. Something like this should work: -
However, there are many others available. Make sure your Windows OS is supported.
