I have a serious problem with about 1 sec sound dropput when 2,12GB file is reached. I am using MAC and since Sony does not support the PMB on MAC - how can I import them correctly og get it from the camera to for instance Adobe Premiere Pro.
Premiere can read the MTS files, but dragged (alone) there is the sound dropout and imported directly with all files available (XML, metadata etc) clips dont "fit" anymore.
Has anyone got any experience with this?
Hello nicketlareriksen - Welcome to the Sony Forums
Although I don't use a Mac myself, in the past I have heard that these issues can be rectified by converting the .mts file into another format such as .avi before importing the video into your favoured editing software.
One such piece of converter software is available here for Mac:
http://www.iskysoft.com/topic-mts/mts-converter-for-mac.html
Hope this helps,
Simon
Hope this helps,
Simon
