hello there. i am new here so i don't know or here i can ask, but don't be mad at me.
i just had bought Sony HDR-CX210E and went to my family on trip. When i am filming someone and end it creates one small clip. now i have 32 small clips, and want to make one big movie, because my parents don't like black screen after each clip. What is the easiest way to create a film of all clips? Maybe possibly to change settings on camera to film one big movie while many small clips. THANK YOU for yours answers.
Hi, welcome to the Sony Forums
Are you seeing any 'buffer overflow' messages before the camera stops recording?
Try recording to a memory card instead of the internal memory. If you are already using a memory card, make sure it is a genuine branded card with a fast write speed.
If you want to combine the clips you already have, you can use PlayMemories Home (that came with the camera) to edit your clips into one long movie: http://www.sony.ie/hub/playmemories
Mick
