Hey guys,
After looking around the net i didn't find an exact answer so i try it here.
My sony Handycam used to work good, but now when i want to record the whole screen is blurry and when i zoom it at some point everything becomes clear, and when i zoom in more it becomes blurry again. So there is like one zoom point where everty is okay, but the rest of the time everything is blurry?
I think the auto focus is ON, All options that i found are on AUTO. So the 2nd option is that the lens is broken? But if so why would it work at some zoom point?
It does sound like the lens or focus motor driver might be broken.
You can find out how to get it repaired here: http://services.sony.co.uk/supportmvc/en/repair
Thanks,
Cass
