Hello All
I have just bought the Sony FDR-AX43 and been recording in different setting modes but when I upload to YouTube the quality is always 720p even when recording in 4K?? Why does it not upload in 1080p am I doing something wrong ??
Hello @Stuzee,
how do you import the files? It seems you activated "Proxy recording" and just used the Proxy files instead of the 4K files recorded in parallel.
The option is called "Dual Video Rec":
I just hope, that you didn't assume you imported the files successfully abd formatted the card afterwards. Otherwise the 4K files are gone.
I recommend to use PlayMemories Home to.import the files from the card to your computer in the future.
- Nic
