Sony fdr-ax33. How to keep the monitor always on? I'm using the camcorder for livestreaming, and monitor turns off after a few minutes. Have disabeled power saving and set the display to always on.
Switched it to off on my other Sony Handycams, but this one I cannot seam to do it, think they should have put it in, there is a power switch so could have been able to in the software.
Take a look at the following page in the FDR-AX33 Help Guide: http://helpguide.sony.net/cam/1510/v1/en/contents/TP0000557902.html
It does say that in 'off' setting that the backlight remains on and that the product does not turn off automatically. Also, although I am not 100% sure, if you have the camera connected to a mains power source rather than just battery, the monitor remains on as well ?
Regards
