Hi there, I'm looking into buying the Sony ECM AW3 wireless mic for my Panasonic SD90 but keep reading conflicting reports of it's compatibility. Some sites and reviews claim it requires external power from a hot shoe, others say it runs on it's own battery power and only requires connection to the microphone jack. Can anyone clarify the truth for me please?
Thankyou.
Hi Marauder, welcome to the Sony Forums
There are two parts to the AW3: microphone and receiver. Both run on batteries, and all that's needed on the camera is a 'MIC-in' mini-jack to plug the receiver into. Assuming the SD90 has a standard mini-jack, it should work fine.
If you need more info you can download the AW3 user manual and the full spec of the device can be found here.
Mick
Thanks Mick, have downloaded and it looks good, will be ordering soon. Ta again.
