Hi, I am trying to find a replacement A/V lead to connect my old camcorder to my TV but every lead I find has a 10 pin round connector, but as you can see from the photo I need a flat(ish) connector. Can anyone help with either identifying the name of the socket on the camcorder or where I can get the lead (I can't find the original part number).
Thanks
Hey @SarahG2005 I think it is better to contact Sony support here so they can check if they can give you the proper part number for the cable, however I think that it might be hard to find it as your camera is a 2003 model, so I guess the parts might not accessible. However, you can give it a shot with them to check.
