hi there. I've been looking for an answer but cannot find it 😕 can you tell me what is the difference between sony bloggie mhs ts20, ts20p, ts20s and ts20k? which one is the best? can you advise me what shoudl I buy if I need it actually jjst for recording while driving?
Hi Dragon_ToE, welcome to the Sony Forums
If you're intending to mount the camera in the car, you'll probably get better results using a basic CCD-based handycam like this, as CCDs handle vibration better than CMOS, which is the sensor in a Bloggie. If it's hand-held, any Bloggie would be just fine.
I'm not sure the various model numbers make a lot of difference for your purposes, unless you're a Barbie fan. The TS20K is a Bloggie with 360-degree lens facility. The other suffixes, when they come after a forward-slash, relate to colour: the TS20/B being black, TS20/S silver and the TS20/P is pink...
Mick
Mick
