Hi
Does anyone know if there is a third party or Sony remote - ideally IR but wired would be OK - for the HDR-CX240E camcorder.
With thanks
Hi there
I believe these are compatible with your HDR-CX240E
From the US Support Site:
Page 21 and 22 of the manual : HERE describe how you can use your Smart Phone to remotely operate the camcorder
However I strongly advise you to contact Sony's Sales line: HERE to confirm compatibility before purchasing. Better to be safe and double check, as this is as much as my Googling can get
Hi there
OK many thanks for that info.
