I'm getting the following error message when importing HD video from my camera to my PC:
"PMB cannot import because you do not have access privileges for the folder to import to"
Any suggestions?
Thank you.
Hi, when you say since upgrade, is this to PMB or Windows, it sounds like a security setting has failed, it may be best to create a new folder in shared users and then link the new folder to PMB, this will prevent any user access issues and you can recover files even if Windows fails
Hi
I meant an upgrade to PMB. I'll give your suggestion a try. THanks.
I am also having the same error message too. Can any1 help plz??
