Hi I tried converting from AVCHD format to MP4 in playmemories, I am selecting to convert using the middle option (1920-1080 25p/30p 14 mbps)
The file size before the conversion is 5.12 Gb and when the conversion is finished the file size increses to over 7Gb..
I have done similar conversions in the past using the older playmemories version, in that version the options to convert to MP4 simply said high, medium or low quality and when I selected medium it would have cut the file size to quater the size, like a 4Gb file down to 1Gb .
So im not sure why the MP4 file size now is ending up larger? Is there any way of rolling back to the older playmemories version?
My Playmemories version right now is: 5.0.03.11020
Camcorder is: Model HDR-CX220E
