Hello, i'd like to ask this: can I use a sony miniDV premium casette with my HDR-HC7E camcoder (miniDV HDV casettes are recommended)? could there by any possible problem with that?
thanks for answers
stark.ma
Hi stark.ma, welcome to the Sony Forums
The premium tapes should be fine with your camera. HDR tape is less likely to produce 'dropouts' in the recorded footage but in practice most cams work just as well with the cheaper tapes
Mick
