Hello Everyone,
I want to record some evaluation comments and need to buy/learn about a mic I can purchase for the interviewee to heard more professionally, not just using the internal mic which picks up all sound. Help required!
Thank you.
Thank you, and just to confirm, would you recommend it for this exact model?
Have you used it with this exact model - FX Sony Handycam AX53 4K.
Forgive me for being so specific - it's because I'm a novice.
Thank you so much for taking the time to reply.
Hello @Condle4l,
I have not used the microphone with the AX53, only with the AX43, AX100 and AX700, but I am 100% certain it works with the AX53 just as well.
- Nic
