iam having sony handycam model(DCR-DVD 808), when ever iam trying to take the snap, getting error "insert memory card" even though i inserted correctly.
Can anybody help me out in this regard.
Regards,
Krishna..
Hi Krishna, welcome to the Sony Forums
My first suggestion would be to make sure the memory card works in a card reader; it may be corrupted. Secondly, try to get hold of another card and see if the problem is the same.
Do make sure the other card is a genuine branded product; ideally ask at the shop where you bought it if you can try a different card in there. There are a lot of fake cards around, mostly from online retailers, which produce this kind of problem.
If the problem persists even with a new card, it could be an internal fault with the camera. Let me know and I'll try to help from there.
Mick
