Hi, I have the Sony HDR-CX115E camcorder. I have a 8GB sony memory stick pro HG duo Memory card (MS-HX16A) which is listed on your website as compatible. I keep getting an error message stating that ‘the memory card may not be able to record or play images correctly’. However it works fine. The trouble is the message that comes up (flashes and bongs) lasting about 8secs which is very annoying. It appears every time I switch on, make a selection or press play or pause etc. Is there any firmware update or any known way to solve this problem? Thanks.
