I have a Sony HDR-CX115E camcorder
Can I use aSDCX SD 10HS1 64GB memory card
If not what is best
Hi johnahy and welcome.
Do you mean SDXC?
You can use SDHC or SDXC up to 64GB (Speed Class 4 or more).
A word of warning. SDXC cards use the exFAT format which may not be supported by your computer. Check first that your connecting equipment supports this format.
