I bought the ax53 camcorder. the manual that came with the camera is tiny, unreadable and does not explain a fraction of the functions on the camera. I am surprised that sony would produce such a rubbish document.
I found the manual on line but it is just the digital version of the same rubbish manual.
Where can i get a comprehensive manual that will explain the camera's functions in simple layman's terms.
Hi, here is the link to the online manual. Select the Help Guide (Printer-friendly) version, this is 224 pages long and has detailed user information.
http://www.sony.co.uk/support/en/product/FDR-AX53#Manuals
Hope this is what you are after.
Regards
Regards
Thanks Jonnie, that's perfect, I'll print it off, Thanks
