Hello All,
I need the manual and driver of sony camcoder: dcr-trv245e ASAP please.
Thx
Dear All,
Any recommendations on how to add a Firewire port to a Sony VPC EB4X5E Laptop?
Many thanks in advance!!!
Was looking at
High Grade - PCMCIA card with 1x 4pin and 2x 6pin Firewire / i.LINK ports - Works with Sony, Panas...
OR at
Hi Ellie
I think either would work well, but I'm not clear about options for that particular laptop.
Might be worth posing your question over on the Vaio & Computing forum?
https://www.sony.co.uk/discussions/community/en/support/vaio_and_computing
Mick
Good luck on what you're trying to do Ellie. There are plenty of people that are willing to help you out. The question just needs to be addressed in the correct place.
Message was edited by: nikkilim
Hi Ellie12,
The E-Series Vaios do not have a PC/PCMCIA card slot - so the two PC Cards you have listed will not fit.
I think you do have an ExpressCard 34 slot - numbered 7 in this diagram: -
So you will need one of these two if you want 6-pin Firewire: -
Or one of these if 4-pin Firewire 400 will do: -
You will find plenty more if you Google for 'ExpressCard34 Firewire'
Thank you so much Blencogo!
I'll let you know how it goes.
