I see a large number of lens hoods on the Sony web site. Can anyone tell be the one for the HDR-CX05 ( one that does not show on full zoom?)
the HDR-CX105 has a 30mm filter thread, so you can attach lens hoods available from 3rd party manufacture. Sony does not offer a dedicated lens hood for the HDR-CX105. I would recommend to test the hood before buying to make sure the hood does not cause vignetting in the wide angle setting of the lens.
Thankyou. I find it strange that Sony did not supply a suitable lens hood.
