Does the SRG-300H has a WebGUI?
I can ping the IP address 192.168.0.100 but it does not open any http/https webgui.Telnet to port 80 doesn't connect, and a port scan with nmap doesn't reveal any open ports. I know that the SRG300-SE have a WebGUI and we can even change the IP address, but not on this one.
Hi ARPCPRO,
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
Hi ARPCPRO,
I've searched for the SRG-300H on the Sony website, but I couldn't find it. I believe this is a professional product, as I found it on the pro.sony website.
I'd recommend contacting them. I found the contact details in this link: https://pro.sony/en_GB/support-services/support-contact-us
Cheers,
The_Black_Rose
Thank you "The_Black_Rose". I did just that and got the answer I was looking for.
"SRG-300H do not have web GUI. Only camera MENU and attached remote commander. Of course camera can be controlled by IP/RS commands too. Details in Technical Manual attached."
