Hi Robeibee,
Welcome to the community.
Can you let us know the model number of your product please?
Thanks,
Ed
The model no is. DCR-TRV60E. Hopefully this helps
Hi Robeibee,
I don't think it is possible to purchase this disc anymore. Also, I believe this version of the app is not compatible with Windows 10.
Cheers,
The_Black_Rose
The only current video transfer software is PlayMemories and you can download it from the Sony Support page for your camera here:-
https://www.sony.co.uk/electronics/support/camcorders-tape-camcorders/dcr-trv60e
However, this only works with a FireWire/iLink connection on your PC as you will see in the transfer instructions on that Support page.
Without a iLink connection, you cannot transfer digital video and the only method is to transfer analogue video to a video capture device which you will need to buy.
You will need the AV cable supplied with your camera for viewing video on your TV. It is shown in your manual on page 59 of your Manual here:-
https://www.sony.co.uk/electronics/support/res/manuals/3081/30814151M.pdf
Instead of the TV you need to connect to a ‘USB Video Capture Device’ which will connect to a USB port on your PC.
There are lots of USB Video Grabbers on Amazon from a few pounds to a few hundred pounds depending on make and included software - make sure you buy a Windows 10 compatible one! Here is one for £21 with software and Win 10. I am not recommending this one as I haven’t tried it - it is just an example for you.
External USB Video Capture Card - August VGB100 - Transfer VHS Home Videos to PC / Capture Xbox 360 and PS3 Gameplay / S-Video and Composite In https://www.amazon.co.uk/dp/B008F0SARC/ref=cm_sw_r_cp_api_i_TTVuDb4WJVCP2
