Hi everyone,
I'm trying to mount lamp to my camcorder, but there is a message: "This accesory is not supported by the the device and cannot be used. Please verify the compatibility with the device". What is the problem? Should i set something in Settings in camera?
In Sorry but...
I think (maybe) because the XML Inputs are too near in NX80.
Thank you Bro! Can you send me link where you found it, please?
Of course, but you have to translate from japanese...:
Thanks
