how do i get my digital 8 handycam to work with vista
It depends which model you have - some work with an update to Picture Motion Browser. Have a look at the table here for the Vista Compatibility for your model.
http://support.sony-europe.com/hotnews/vista/vista.aspx?site=odw_en_GB&sc=D8
Sony gave notice that Legacy Camcorders would not be supported with Vista or Windows 7. However, it may be possible to copy video files to your PC using iLink.
its a dcr trv 265e model. the software that came wit it was for xp and my computers vista so i never was able to use it?????, i thought vista was a more recent system.
Picture Package will not work with Vista.
Your model should work with the newer Picture Motion Browser - you can download it from here: -
i ve tried to download picture motion browser as you told me but i don t have the codes it s looking for. i ve misplaced the origional cd. is their anyway around this. regards padraig
