I can connect to my HDR-XR520V from PlayMemories Home perfctly.
everything works weel but not the posibility of DELETING PICTURES from the camera.
Neither from a MemoryStickPro inserted nor from the HardDisk.
Both are "write enabled".
Any help would be appreciatyed.
Software is up to date.
Hello djlutz
According to the manual here, you should be able to:
"If you click [Settings] and put a check in the [Delete imported media files from the device or media] checkbox, videos and photos will be deleted from your camera after they have been imported to your computer."
Does this help at all?
Kind Regards,
Clarissa
