When i record a video i get in the left hand corner of the screen, just under the menu button some smal text saying: NO GPS SIGNAL. How do i fix this? I want the GPS to work, that was one of the big reasons i got this camera.
Hi Zargato, welcome to the Sony Forums
You need to be sure the camera is able to triangulate your position. GPS works via connection to a minimum of three satellites in Earth orbit, so you do need to be located in an open, unobstructed place to be sure of accurate positioning. If you power the camera up and it hasn't previously locked your position, you may need to move into an open outdoor space.
There are some explanatory notes for your camera's GPS requirements here: http://pdf.crse.com/manuals/4416294111/gb/contents/09/01/02/02.html
Mick
