Hi all
When projecting video the projection display on my HDR-PJ10E handycam is snowy. This happened slowly over approx. 20mins and first appeared to be rain on the lens which got progressively worse. The projected image can still be seen but only just. The LCD image is fine and the camera records new video okay. The projector lens is okay with no marks or dirt. The brightness of the projector is very good and I don't suspect the projection bulb etc. to be the problem. I'm thinking there must be a small CCD or mirror at fault.
Is there anyone able to advise on what the cause might be and the remedy.
Many thanks
Hi there,
It would be best to contact the Sony Support team here for further help with this issue.
Best wishes,
Sean
