Hi.
How to convert MTS file from cam to any format that can play my DVD recorder? If it's true that MTS is HD quality format and my recorder can play only SD quality then I need to convert MTS. Right?. Which format do I need and which program should I use? Does PlayMemories have convert & burn feauture?
