Have just bought the HDR GW66VE and want to preserve the lens as the camera will be used in the kayak. Is there no protection filter or a polarid filter to be mounted on existing lens.
Or tips on making a filte yourself?
It is mentioned in the manual that there is conversion lens but I can not find anything on your website
for the HDR-GW55/66/77/88 the wide angle attachment VCL-HGE08G is available (it seems currently only in Asia)
http://www.sony.jp/handycam/products/VCL-HGE08G/feature_1.html#L1_10
The camcorder itself does not feature a standard filter thread so you can not mount a protection filter to it. The camcorder however is quite rugged and usually does not need a special protection filter.
