My HDR-CX625 camcorder, not even four months old, will not turn on. It just sticks on the "Handycam" opening screen, loops three times then turns itself off. I have checked Sony for help and they won't even repair it, they just say things are "in-warranty exchange" and are not economic to repair.
Does anyone have any guidance on how to fix this?
Apologies for the delay in responding.
The shop I purchased the camera from have now agreed to replace it so I will have a working camera from tomorrow. However, I can confirm that there is no way to externally power the camera without a battery attached.
This is the second CX625 camera I have had and both have died with the exact same issue. I am hoping this third one on the way does not do the same. I have no idea what the problem is or what the cause of it is so it is impossible to try and avoid it somehow.
Thanks again for your assistance.
I also have the same problem has anyone come up with an answer ?
airandsteam
Try the following:
- Disconnect the power source, attach the power source again after about 1 minute, and turn this product on.
-Initialize if you can get the menu:
https://helpguide.sony.net/cam/1610/v1/en/contents/TP0000933344.html
