I am tring to control my HDR-CX190E camcorder via HDMI on from my Bravia TV. This works for other decvices such as my DVD and PVR. When I try and add the HDR in the sync menu it does not find the device. I have enabled HDMI control in the HDR but still not working. Any ideas? The camersa plays back fine through te TV its just that I cant control it.
Hello 1000dogs - Welcome to the Sony Forums
If you have already switched on the Control for HDMI feature by using the instructions on this page .....
http://pdf.crse.com/manuals/4416966111/eng/contents/07/07/10/10.html
..... there is no reason why your Bravia shouldn't be detected the CX190E. I'm not too sure about how this function works on a Bravia TV, but if you cannot get an answer in this area there is also a dedicated Bravia section to these forums where the users may be able to offer some further help with this. It is located here:
http://www.sony.co.uk/discussions/community/en/support/tv_home_cinema
Thanks,
Simon
Thanks Simon,
I'll try the Bravia forum. Someone else must have seen the same issue.
Matt
