I have a filter to protect the lens on my HDR 780. If I fit the filter I cannot fit the lens hood. It won't fix on properly. It seems to be a filter or the lens hood but not both which is odd.
I am not sure but if your filter features a 52mm filter thread on the side not facing the camera you should be able to mount the lens hood on it. Have you tried?
