HD190 or HD190e (is there a difference?
Could anyone please tell me the difference (if any) between a HD190 and a HD190e Camcorder
Hi sangeo, welcome to the Sony Forums
There's no physical difference but sometimes firmware etc can differ.
The 'e' on a Sony camera denotes a European model, to differentiate it from those designed for use in the US or Asia.
Firmware may adapt the camera video settings to work in a different region; you may also find the warranty on an 'e'-designated model will not be valid outside of Europe.
Hope that's of some help.
Mick
Mick
Many thanks Mick. I can now buy with confidence, that I am not missing anything concerning the "e" if not advertised with it stated.
Sangeo
