Ik heb een HDR-H5E en wil in HD kwaliteit uploaden naar Apple iMac; met welk kabeltje lukt dat?
I've got a HDR H5E and I want to upload in HD quality to the iMac; what cable should I use? The ones that came with it in the box don't seem to do it for me.
What cable have you got? FireWire? or USB Cable.
Ever things works if you know how.
You want to import to iMac unto what software iMovie or Final Cut Pro or Final Cut Express?
In your iMac check if you have Firewire and USB. I think they have done away with Firewire on the new models, but not certain.
I do have an i Mac with Fire wire and USB, so is there something linking iLink and Firewire maybe?
