Hi guys I’m struggling I have a Sony handycam DCR57E which I bought back around 2012 it’s been stored away and I’m wanting to use it on a walk of the dales. My problem is the memory card is missing and I’m struggling to where I can get one I’ve checked out eBay but had no luck any chance any body knows where I can get 1 from
Many thanks Mick.
Hi Mick,
Did you try to find them on Amazon?
However, you do not need a memory stick to record something.
Basically recordings are stored on the internal HDD of this camcorder.
Hi
Thanks so much for your help I've ordered 1 off amazon so fingers crossed
